40-190 Output Transformer
Hello
I just got a used transformer, Philco # 32-8053. It reads 309 ohms black to white, 143 ohms from ct to black, and 166 ohms from ct to white. The schematic has 210 ohms ct to black, and 240 ohms from ct to white. I noticed that the bad transformer has an M after the part number. The used one I got has an N after the part number. Will this one work or is there a way to make it work? The parts list dose not have a letter after the number.
Thanks for any help
Bob
Bob, I would not be too concerned with the resistance readings of the replacement transformer. More important
is the voltages. Are the voltages correct? If so it should be OK. PL
Just a couple of more things to check before you fire this one up again, check the two output tubes (type 41) for shorts or evidence of arcing at the tube sockets, and then bring the set up slowly with a variac and monitor the B+. If there is a short in either of the output tubes, or arcing at the tube socket, your replacement output transformer will be in peril. Just for fun, you can carefully open up the old output transformer, and see if the "open" is just a lost connection, or a burn out caused by excessive current. I have seen quite a few cases where the connection of the fine primary windings to the cloth covered leads corrodes, or arcs to the transformer casing, and sometimes this can be fixed. Since this is a push pull transformer the primary is center tapped and you may have continuity in only half the winding. If you do have some contiuity and no shorts to the metal casing, save the transformer. You may need it someday to replace a burned out choke.
Want to thank you both for the info. I am still stripping the radio down ( hope I can get it wired back up again Icon_eek ). I am a retired machine tool electrician so this is all new for me, but it is fun. Am learning a lot from this Phorum and other web sites. I didn't see any signs of a short and the 41 tubes check alright. I think I will do as codefox1 suggested an take the old transformer apart. I'll let you know what I find if anything.
Thanks to both of you
Bob
Philco 91 Restore Code ??
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 3132 online users. [Complete List]
» 3 Member(s) | 3129 Guest(s)
