New guy with a PT-6 to Restore
I agree that stain can be used but I like my toner. Stain cant cover defects like toner and I like to keep everything as factory as possible. The front curves would stain nicely with golden oak but the other areas I mentioned are quite dark and stain will not look right. You will see too much grain from the crappy underwood.
You can always try stain and then tone over it if it does not come out right.
Kirk
Sounds good...I think toner will be the winner!! Still cant find SD card so ill try to get pics of the things I need to fix.. thanks for all the advice so far!
Ok, now the bad..Sorry for the pics but I had to use my tablet..not the best camera!!
Crack in bottom side of cabinet..(you can see the veneer lifting on the front panel too)
[img][Image: http://i100.photobucket.com/albums/m5/Fr...113115.jpg][/img]
Side separation from top of cabinet
[Image: http://i100.photobucket.com/albums/m5/Fr...113053.jpg]
Crack in veneer..there are some on the bottom of the front panel too..
[Image: http://i100.photobucket.com/albums/m5/Fr...113042.jpg]
Also the bottom piece separated into 3 separate pieces when I took the chassis out...It seems in good shape otherwise!! Might get away with re-gluing it together!! If not, ill have to make a new one...
As usual any and all ideas welcome!!
You might be able to work glue into the cracks and separation in the first two pictures.  A glue syringe might help.  Then clamp.  The cracked veneer on the curved portion of the radio is difficult to repair.  See the threads below:
http://philcoradio.com/phorum/showthread...r+cracking
Quick side note....ive noticed in a lot of cabinet restorations on here, that some of youse to know the wood used to build certain cabinets...where did you find this info or is it info learned? It would seem to be great info if a piece need to be fabricated new....just wondering!
Philco 91 Restore Code ??
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 2413 online users. [Complete List]
» 4 Member(s) | 2409 Guest(s)
AvatarAvatarAvatarAvatar
