Model 70 Speaker Problem
Several months ago I "rescued" a Philco Model 70 from a thrift store. I'm in the process of collecting a speaker, output transformer and other missing components.
A few days ago I purchased a Model 70 speaker with attached output transformer. Unfortunately, the field coil and primary winding of the output transformer appear to be open. (For guidance I'm using Ron's informative Tech Section article titled "The Speaker Problem in Early Philco Cathedrals.")
Has anyone repaired or rewound one of these field coils? I understand the center of the "pot" is pressed into the frame. I'd appreciate any advice (e.g., disassembly, technique).
A post on the Phorum states that replacement output transformers are available from Hammond. I'd prefer an original. As with the field coil, I'd welcome any advice on repairing or rewinding these transforms. Alternatively, has anyone used an individual or business that performs these services? Ron's Philco Resources mentions Heyboer Transformers. Is this cost effective or should I renew my search for a good used speaker and output transformer?
Allen Bell
Santa Barbara
Hi
An original audio output transformer for a Model 70 speaker that is still good is going to be rather difficult to find.
Having a transformer wound by Heyboer is not cost effective if you plan on "flipping" the set. If you really like the set and want to keep it, then yes, the expense is worth it. Heyboer does excellent work, by the way.
The field coil problem was recently discussed in another thread...
http://www.philcoradio.com/phorum/showth...p?tid=1465
Ron:
Thanks for your reply and the thread. The Model 70 is a "keeper" so I requested cost estimates from Heyboer and Tubes Tubes Tubes for rewinding the field coil and output transformer. I'll pass on the results.
Allen in Santa Barbara
PS: As a newcomer, I'd like to say "thanks" for all your time and effort. I've relied on your website countless times before and after purchasing my two Philco radios. (My other set is a Model 620.)
Philco 91 Restore Code ??
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
There are currently 2711 online users. [Complete List]
» 2 Member(s) | 2709 Guest(s)
