511 series AF transformers
After replacing a burned out 71A tube I was getting one strong channel but no volume control. I figured I'd recap it and see what I got. While waiting for the new caps to arrive I went through the chassis more thoroughly and found that the output choke was taken out of the circuit with the speaker connected directly to the 71A and worse, the 2 AF transformers (#3077) appear to be open... I doubt I'll be able to find replacements and I don't want to put a lot of money into it. Is it possible to rewind these myself or use some modern replacements?
Hi
While these can be rewound, modern replacements are available for the audio interstage transformers from a few sources. You will want transformers with a 1:3 ratio.
Or, you could change the audio interstage transformers to resistance coupling. Details here:
http://www.philcoradio.com/tech/audio.htm
Scroll down to "Modification C."
Thanks Ron, I will try the resistance coupling if I can't find an appropriate match. This may be a silly question but, could I use a 110v to 36v power transformer (1:3 ratio) as a substitute? Also what kind of current rating should be used?
Philco 91 Restore Code ??
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
Compatible crts
Bob Andersen — 08:58 PM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a "...Arran — 08:41 PM
Restoring Philco 96
There are currently 3258 online users. [Complete List]
» 3 Member(s) | 3255 Guest(s)
