Philco 41-260 radio restoration
I have a 41-260 Philco that does not work electrically.  I am looking for someone in the Michigan, Ohio, Indiana area to do the repair on the radio.  Also, anyone in the Daytona, FL area would work as well.
Thank you in advance for your help,
Jim
Welcome to the Phorum Jim!
In addition to any leads that might develop from this phorum you can contact the Michigan Antique Radio Club who should know of folks in your area that might be able to help.  Jean and John have been in the business for quite awhile and are in Indiana.
