1943 Philco console radio
Does anyone know where I can have the speaker reconed on a 1943 Philco console radio in the Dahlonega, Ga. area?
Thank You,
Barbara
You can try Hank- Hank Brazeal
3850 Galleria Woods Dr., #8
Burmingham, AL 35244
Ph: 205-403-6243
E-mail: hankspkr@charter.net
