Sani Wax
I have used Sani Wax for years. It's the best for cleaning and polishing furniture, wood panneling, vinyl and plastics. I like it because it works so well and I don't have to dust as often. It makes everything look new again. I am running out and looking for a store that sells it here in NW Arkansas. The bottle says it is also good for ceramic tile, appliances, counter tops, chrome and marble and laminated surfaces. Hmmm. Didn't realize that.
hi duggak
welcome to the phorum
sam
There are currently 10252 online users. [Complete List]
» 1 Member(s) | 10251 Guest(s)
