Finally Completed!
The electronics were not too bad (except that super stuck band switch). Even the Bakelite blocks went fairly easy. The cabinet was more of a challenge. I ended up replacing the veneer on both sides and the top. The grill cloth is new also. I think it came out pretty good. By the way, It sounds great and picks up a lot of short wave, too Icon_clap
Eric
The Villages, FL
Came out great, Eric.
Thanks, Morzh! At least I learned how to free up a frozen band switch.
Eric
The Villages, FL
Very nice Icon_thumbup
yeah....the word switch rhymes well with you know what for a reason, huh? Icon_lol
nice job it came out quite nice.
Great job! Icon_clap Icon_thumbup Icon_clap Icon_thumbup
M R Radios   C M Tubes
Great job you did there Eric  Icon_smile
I recently got a 66B myself and I must say the cabinet style is quite the looker in my opinion.
Super lookin' job!!
Icon_clap Icon_clap Icon_clap
Eric,
Beautiful job!!!
What did you have to do to the band switch to get it moving? I've not had a frozen one yet, but I hear it happens, so it would help to have an idea how to deal with it.
Really good job. Where did you get the large pieces of veneer?
PAradiogeek: If you read this thread: http://philcoradio.com/phorum/showthread...110&page=2  It will give you an idea of how to free up the band switch.
Mike: I got the veneer here: Rockler I used the pressure sensitive type. It is really easy to work with.
Everyone else: Thanks for your comments. It  means a lot when I hear it from my friends on the Phorum Icon_thumbup
Eric
The Villages, FL
There are currently 9707 online users. [Complete List]
» 2 Member(s) | 9705 Guest(s)
