40-165 Tube layout label
I think you are right Arran, the circles for the 84 and the 41 should have the same center line as the other tubes.
As it is now, the CL of the 84 and 41 are offset upward.
I think the circles are centered correctly.  I used a photo from a 40-160 radio that Dan sent me for a template. The black border I added for sizing and will be used as a cutting guide and will not be in the label.
Keith
Interesting...the 40-160 uses Copperplate Gothic Bold, not Copperplate Gothic Condensed Bold for the "PHILCO" name and, apparently, for the "REG. U.S. PAT. OFF" below that...without the extra spaces between the letters.
There are currently 10331 online users. [Complete List]
» 1 Member(s) | 10330 Guest(s)
