42-1003 model 121 decent schematic
Got philco 42-1003 model 121 rider schematic is  illegible as far as values for components esp on the electrolytic s, the three in a single can, I can't read tried to clean it up but the larger it gets the worse it becomes. any suggestions?[Image: http://philcoradio.com/phorum/images/smi..._crazy.gif]
(11-29-2014, 09:23 PM)mountain man Wrote:  Got philco 42-1003 model 121 rider schematic is  illegible as far as values for components esp on the electrolytic s, the three in a single can, I can't read tried to clean it up but the larger it gets the worse it becomes. any suggestions?[Image: http://philcoradio.com/phorum/images/smi..._crazy.gif]
Order schematics through Chuck . http://www.philcorepairbench.com/schematics.htm
I have to say chucks schematic`s are great
lot of info and large print  only 7.00  great deal  Icon_clap Icon_thumbup
id #60 is 10 @ 25v
id #72 is 40-40 @150v
sam
(11-30-2014, 12:21 AM)mafiamen2 Wrote:  I have to say chucks schematic`s are great
id #60 is 10 @ 25v
sam
thanks for the info will contact chuck.
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
