42-1003 code 121 bol
working on this radio the schematic shows beam of light in the diagram but this unit does not have it, can not tell if std or deluxe model, maybe some one changed out to a regular tone arm any suggestions or info on this.
The Model 42-1002 looks identical, except for the skinny
crystal pickup tonearm.
Chuck
pic`s would be helpful too
Chuck,  as you can see it is 42-1003 model 121 so no confusion there. hoping to get your schematic soon so i can get a better view of the internal works of this set.
hmm whats the tube line up
1001 is 5, 1002 is 6 , 1003 is 7 tubes
could be a 1002 chassis but marked 1003 ?
sam
(12-09-2014, 02:59 PM)mafiamen2 Wrote:  hmm whats the tube line up
sam
7 tube
Well looks like you need to find Bol arm and rewire it   Icon_problem
Your packet mailed out on 12-8. You should see it very soon.
Chuck
Model 27-84 BUZZ?Humm?
Philco 630csx power cord
