ge speaker repair
come on get a laugh
http://www.ebay.com/itm/vintage-LATE-40S...4d1b8e3870
sam
Professionally repaired? By what type of professional? Wrestler, maybe?   Icon_lol Icon_lol
Eric
The Villages, FL
While it has not been reconed, (is this what's expected from a pro?) - what's really so egregious about the repair?
I don't know, I'm not a professional. But when I repair a speaker with a white patch, I color it so it doesn't stand out. He could have said, "Somebody patched it for me".
Eric
The Villages, FL
looks like it had a voice coil that was removed,  probably where that hole come from
if he`s a pro maybe we all are  and don't know it Icon_clap
I think you got it, Sam!
Eric
The Villages, FL
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3451 online users. [Complete List]
» 1 Member(s) | 3450 Guest(s)
