A cone crack - what is the best quick repair?
Threads: 55
City: Evanston, IL
Single layer of small strip(s) of tissue paper soaked in diluted Elmer's white glue (50:50) applied both sides, but just wide enough to bond the crack/tear without unduly stiffening a large area. Also, take a cotton swap in warm water to "pre-wet" the tear edges (both sides) for a better bond the to the dry cone.
Chuck
Threads: 566
I bought contact cement today, did three layers on each side...will see how it behave.
Threads: 310
City: Kings Park NY
There is this great tutorial for speaker repair that someone posted but I cant remember the name........
Oh I know ... ME!
That was before I knew about Syls tutorials.
http://philcoradio.com/phorum/showthread...l#pid64287
Kirk
AC: 4 DC: 1
Threads: 18
There is a glue for replacing speaker surrounds that is just right. For a small tear, artist's rubber cement is fine, although the days of paste up artists has passed, good luck getting it a reasonable pricel
Threads: 566
Kirk
The problem is.....I drink ESPRESSO!!!!
Threads: 310
City: Kings Park NY
With beer?
Why am I even bothering to ask
Wait, beer before espresso makes quite the messo
Espresso before beer you're in the clear!
Just made that timeless quote up..
AC: 4 DC: 1
(This post was last modified: 12-19-2014, 04:29 PM by OldRestorer.)
Threads: 337
City: lawrenceville nj
think some one is still on happy pills
Threads: 566
Exactly.
Happy pils. Which one is that, The Bud? (it is an unhappy pils for me, I prefer Czech)
Threads: 38
City: Tustin
I used service cement for years but the last couple years I have been using products made by Springfield speaker repair. A lot of guys that do Hi-Fi speaker repair use their CSA and rubber cements. I finally gave them a try and found that they work very well.
Threads: 310
City: Kings Park NY
You prefer Czech's,
I prefer ca$h.
But I'll take a Czech no matter how much it's written for!
Kirk
AC: 4 DC: 1
Threads: 566
Note to self:
Check for a check for Czech beer. Check!
Threads: 103
City: Calgary, AB, CA
On any speaker repair that I have done ,I used'' Pliabond'' It is made by Goodyear and it never gets hard.
I am not sure where you can get it .. I get mine at Home Hardwar.
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
