AK808A
#61
Edison....never worked one one.
Then again, I never worked on a heck of a whole lot.
Mostly Philcos.
Well, they are not that different after all....except for AK usin 58 tubes everywhere, same thing...
#62
mike
come on don`t be so modest we seen the stuff kirk gives you Icon_crazy
you moving after new year ?
hey thought for ya  kirk can make a bed in you new garage
sam
#63
I have a pool table there...and a sauna. And there is a dedicated beer fridge. Huh? Oh, and a bar stand too.
#64
(12-19-2014, 11:01 PM)mafiamen2 Wrote:  good job mike can`t wait to hear it in your new place   Icon_clap Icon_clap
p.s. I have an Edison radio for you to work on Icon_thumbup
 Edison radios don't appear to be anything exotic, Edison bought out Splitdorf around 1927-28 (and overpaid for the company) after the old man retired and the son took over. From what I can see they are pretty much your standard TRF circuit with typical late 1920s and early 30s AC tubes.
Users browsing this thread: 20 Guest(s)
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 6686 online users. [Complete List]
» 1 Member(s) | 6685 Guest(s)
