46-1201 (code 121)
I'm having some trouble finding a schematic for a 46-1201 code 121, which I understand is substantially different that a code 122. Does anyone have this schematic? Thanks in advance!!
Does your radio use a 50Y6 rectifier tube?
If it does, I can get the schematic for you.
Carl
Northern Panhandle, WV
Yes it does. Thanks Carl!
Service info e-mailed.
Carl
