Philco 91d restored
                       Wanted to share this  philco 91d also , Ron if I should post pictures somewhere else let me know
Another nice one.
Looks great Fred! I've got a 91D myself, the late 2 band 1933 version. It sounds really nice with that big ol' speaker Icon_smile
Fred you always restore your radios beautifly!
(01-20-2015, 08:37 AM)PhilcoJohn Wrote:  Fred you always restore your radios beautifly!
Thank you very much . Fred Taylor
There are currently 10488 online users. [Complete List]
» 4 Member(s) | 10484 Guest(s)
AvatarAvatarAvatarAvatar
