Restored Zenith Consoles
[attachment=621        Wanted to share pictures of some  zeniths ive restored last year
WOW great job Icon_clap Icon_clap Icon_clap
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
