Restored 1930s consoles +
                       Here are some more radios ive restored
Very nice work, don't know th model off hand, but is there a question here?
That there is a Atwater Kent  model 317 from 1936, last year for Atwater Kent radios I believe.
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3739 online users. [Complete List]
» 1 Member(s) | 3738 Guest(s)
