Philco 16b found dead
      Saved another,  heres how I got, rebuilt the cabinet ,next post will show it  refinished, then in electrical section will show the guts/before and after
Wow, great job resurrecting that cabinet!
Hympty Dumpty?
There are currently 10559 online users. [Complete List]
» 2 Member(s) | 10557 Guest(s)
