Philco 84 4989-AK Block
This block calls for (2) 0.09 Caps.
I only have a pair of 0.08 @ 630v. , will this work?
or do I need to find the exact ones or any equivalents you can suggest ?
thanks in advance
What you have will be fine. Capacitance value not critical, just voltage rating.
630 v. caps are fine.
Chuck
Just to play it safe, I replaced the 0.09 with 0.1 630v.
thanks
There are currently 5725 online users. [Complete List]
» 2 Member(s) | 5723 Guest(s)
