0.00011 mf caps in bakelite blocks
I'm working on my model 116.  What is the concensus?  Are these 0.00011 mf capacitors replaced during restoration?  On one hand, that value suggests they're mica, which is usually left alone.  But on the other hand, why would these capacitors be potted in tar?  This suggests they are subject to degradation over time.
Inside backelites these are not mica.
Even if they are safe they have likely drifted, they are typically replaced.
I've always used dipped mica 110pF caps here; they are cheap and perfectly suitable for the purpose. I buy at least 20 at a time. These are the caps that look like dark caramel candy.
Pete AI2V
From all of the Philcos that have crossed my bench...and they number in the hundreds, I never bothered to count them...out of those that have 110 pF caps in bakelite block shells, the majority were small paper caps. I have encountered a few that had mica caps encapsulated in the tar, though...but as I said, the majority were paper.
As Pete (AI2V) said, dipped micas are excellent replacements for these. And, yes, I replace them as a matter of course in the Philco sets that use them.
[Image: http://www.talonix.com/images/caps4/39pfDSM.jpg]
Looks like this.  Some are larger or smaller, depending
on the capacitance and working voltage.
I just pulled 4 of those out of bakelite block shells last week and all 4 were paper. I used the dipped micas like in Chuck's photo.
Another question, about the voltage rating on these caps; what were they originally? I would assume 500V micas would be fine?
Yes 500 volt micas will be OK.
Can you double check that? The bakelite block I'm restoring is pn 8035-DG. Philco Service Bulletin No. 289 suggests these capacitors have a working voltage of 1200v.
The maximum voltage these are going to see in the 2nd Detector circuit will be so low as to not be consequential, really.
You can use 1200 VDC caps if you wish. H**l, you can use 12,000 volt caps if you want to. But Codefox is correct, 500 WVDC caps are fine. Even 300 WVDC micas are fine. I use the 500 WVDC micas all of the time to replace these and I haven't had a single failure yet...and I do not expect to since they will only be exposed to somewhere between 0 and 10 volts in this circuit.
(12-09-2014, 05:19 PM)Kestas Wrote:  I'm working on my model 116.  What is the concensus?  Are these 0.00011 mf capacitors replaced during restoration?  On one hand, that value suggests they're mica, which is usually left alone.  But on the other hand, why would these capacitors be potted in tar?  This suggests they are subject to degradation over time.
Hi guys, I have run into the same bakelite block in my 38-2 as Kestas.Just a question would 0.0002 @ 630V be to much to use in place of the 0.00011? I have these on hand,but if I have to I will order the correct replacements.
Thanks
Quote:Just a question would 0.0002 @ 630V be to much to use in place of the 0.00011?
You should stay within a 10 to 20 percent tolerance.
Just ordered up some 110pf caps so i should be good until I tackle THE BEAST my 38-116. After the 38-2, i
would hope things will be easier,still will be a challenge I know. Icon_thumbup but I'm up for it.
Oh...it's just a bunch of wires, glass an metal....nothing a man with a scredriver couldn't take on.
FIRE UP that soldering iron an lemme at it.Wait, I still have to finish the 38-2. Icon_biggrin
There are currently 10653 online users. [Complete List]
» 3 Member(s) | 10650 Guest(s)
