Anyone Know the Model of this Zenith?
I'm trying to identify the model number for this Zenith. Anyone know?[attachment=0]
"Ignorance is bliss...'til you have to fix a radio..."
8-S-359 from 1939 model year.
http://www.radioatticarchives.com/radio.php?radio=3688
Sean
WØKPX
Thanks Sean!
