Threads: 367
City: Dover, OH
(This post was last modified: 01-30-2015, 04:33 PM by Jayce.)
Threads: 55
City: Lexington, KY
Threads: 367
City: Dover, OH
It's quite a price jump from the basic model 17, which cost $130!  No wonder they only sold around 3000 of the model 50. In fact, I could have had three model 17's for $90 a while back, with some tubes! Sadly, they were all missing the dial light hoods.
An article I read on that same site says the Radiola 17 was RCA's first true AC radio. Would that make the 50 their first true AC console? Being from 1927-28, these along with my Radiola 33 do seem to be the earliest all AC radios I have seen. Yes there were models like the Radiola 30-30A, but those were more like a hybrid of battery set combined with an amp/battery eliminator chassis.
Threads: 310
City: Kings Park NY
Ummmmmmmmm, Is that ATARI Pole Position???
I think it is and I want to come play it,
Kirk
AC: 4 DC: 1
Threads: 31
City: Lapeer
State, Province, Country: MI
Great find!
Joe
Threads: 367
City: Dover, OH
(02-02-2015, 07:15 PM)OldRestorer Wrote: Ummmmmmmmm, Is that ATARI Pole Position???
Kirk
Why yes, that is an ATARI Pole Position. In fact, it is a Pole Position 2! Needs the monitor recapped though... Took two machines to get enough parts and a decent cabinet to make one. So far, $140 invested, which is cheap for Pole Position! These things can be nightmares!
Threads: 33
City: Horsham, PA
Jayce,
I'd love to see a picture of the underside of that chassis. Is it all original under there?
Threads: 367
City: Dover, OH
Both chassis look untouched as far as I can tell. First, here is the IF chassis. Pretty simple underneath except for what looks like a capacitor can.
Next is the power supply. Three Rheostats? (Am I spelling that righ?) I knew there was one which seemed to act as a hum control, but three? What do they do? Nothing on the schematic I found mentions these, but it appears this is the way the 17 was built. All three are adjustable from the top, though you need a long shanked, skinny screw driver to reach the one.
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
