original colors for a philco 60B early version
I was reading a post on the other forums about a guy refinishing a philco 60
Here is the link with the photos, My 60 is in the same condition. what are the original colors?
How would you handle the finish if stripping is not desired?
http://www.antiqueradios.com/forums/view...7&t=271078
Kirk
Here's a thread on the topic:
http://philcoradio.com/phorum/showthread...ilco+60%22
Thanks Bob,
You are a guru of this site Icon_lol
Kirk
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
There are currently 3506 online users. [Complete List]
» 3 Member(s) | 3503 Guest(s)
