Philco model 19B I.F.
I have just restored a Philco chassis 319 ( Made in Canada version of 19/89 ) and am about to do an alignment on it.
I am confused since the I.F. frequency is indicated as 260KHz or 460KHz depending on what document you are using…
Can anyone provide a definitive answer on the I.F. frequency of the 319 chassis which was used in the model 19 series in Canada? I am going to guess 460KHz for now…it would be obvious I assume once I start the procedure…
Nope, the proper IF frequency for model 319 is the same as the USA model 19 - 260 kc.
(I checked the RCC data to be sure.)
(02-28-2015, 07:31 PM)Ron Ramirez Wrote:  Nope, the proper IF frequency for model 319 is the same as the USA model 19 - 260 kc.
Thanks for the clarification Ron.  By the way this chassis works quite well even without an alignment...even the shadow meter still functions!  What I have also noticed is that the sound quality with the lowboy/console 10 inch speaker is quite good and there is basically no sign of 60/120HZ hum...very nice radio to listen to.
Thanks.
PH
Welcome to the Phorum!!!
(03-02-2015, 10:10 AM)klondike98 Wrote:  Welcome to the Phorum!!!
Thanks Bob...I have one more Philco to restore ( a floor model from 1939...)...might get to it in the fall...
PH
Philco 630csx power cord
Model 27-84 BUZZ?Humm?
