Philco Model 81-need help please
House GND is the Earth GND.
A waterpipe is a good one.
Or the GND pin in the power outlet.
(03-03-2015, 05:11 PM)Radioroslyn Wrote:  Earth ground is best. Shouldn't blow gfi or breaker unless the cap that from the ac line to the chassis is bad.
Thanks Terry.
(03-02-2015, 03:08 PM)Jay Thomas Wrote:
(03-02-2015, 01:34 PM)Bill Bacco Wrote:  If you are interested in some changes I made to my 81 Jr to address the volume issue, check out the following thread.
http://philcoradio.com/phorum/showthread...2#pid38812
Bill
Thanks Bill.  May be the next thing I will try.  This seems to put the volume control in the output circuit where later models have them.
Jay
Hi Bill:
I made the changes in your diagram to my delight!  Grounding the receiver was not an option for me.  With the circuitry change I can now control the volume from zero to loud on the strongest stations.  I do not notice any distortion at any volume level and I now receive more stations than I did before the changes.  Amazing!  Thanks much!
Jay
If you would like to raise the sensitivity that 1.2k resistor seem a bit low unless you have a 50,000w AM blowtorch near. The original was 20k. I'd play with that value. Try  5,10,15K. If you live in stickville you can just remove that resistor.
