Threads: 310
City: Kings Park NY
i am snowed in today so I am re-capping a Tradio for my uncle. I have a resistor with a brown body, yellow stripe, red stripe , red stripe. I only have the list for body, end , dot.
Where can I get the one for these and what is its value?
Thanks guys
Kirk
Image(s)
AC: 4 DC: 1
Threads: 566
Looks like 220K. red-red-yellow= 22x10,000 = 220,000 Ohm = 220K.
measure it first, see if it is in the vicinity.
Threads: 310
City: Kings Park NY
Thanks, I now have grey, red, brown with a 10% tolerance. That is 8200 ohms?
Kirk
AC: 4 DC: 1
Threads: 19
City: The Motor City,Detroit MI
820 Ω.
You may want to download this link. It has a lot of good information. Resistor codes are on Page 73.
http://www.vacuumtubeera.net/Allied-EDH.pdf
There are many more resistor tables available on the web in color.
(This post was last modified: 03-05-2015, 02:27 PM by
Kestas .)
Threads: 310
City: Kings Park NY
Ok,
Another question...
The electrolytic is 40,30,20, where do the negatives go? To ground? Mike! You needto yeah me to read these D**n schematics
http://www.nostalgiaair.org/PagesByModel...021846.pdf
AC: 4 DC: 1
Threads: 337
City: lawrenceville nj
mike
theirs another one you will fix told ya he`s not doc holiday
Threads: 566
geez dude I ain't saying you gotta be able to read all that noodly stuff but cain't ya see the negative (common for all three) goes to the S1 switch or possibly a wire coming from it somewhere on some solder post?
BTW don't call them 40, 30, 20 as on the sch they are C8, A, B and C sections. This is called reference designator and those are for referring to the parts.
Threads: 310
City: Kings Park NY
Say what?
AC: 4 DC: 1
Threads: 337
psst mike
when talking to kirk
you have to put it into colors red crayon to here. green crayon to here and all the black crayons go together here
Threads: 566
S. Reads as "a**". Well, since the censor corercts it, it is another word for a Donkey.
1. reads as "Juan".
S1. "a** Juan".
Switch. You know. The clicky do-hickey. Makes clicking sound and connects Mains to your radio.
let me know the level of decomposing, I will oblige.
mua-ha-ha-ha.......
Threads: 310
City: Kings Park NY
Ok well I am looking and I don't see a direct wire to the switch. Can I just run the negatives to the chassis ground?
AC: 4 DC: 1
(This post was last modified: 03-06-2015, 10:39 AM by
OldRestorer .)
Threads: 566
No, they are NOT to the chassis.
Again, look at the power switch (probably coupled with your volume?).
One wire goes to the power cord, another should go to the filaments' string AND to the negative of these caps.
This is NOT a hot chassis radio, and the chassis is coupled into that negative via a capacitor C16. BTW one pin of that C16 is on the chassis and another is on that negative plus power switch plus filaments.
Threads: 310
City: Kings Park NY
Yeah, I didn't get that
What does it mean when it says "can is common negative? That's what the can has on it. Maybe it is not that schematic? This radio is not marked so I was going by the picture.
Kirk
AC: 4 DC: 1
Threads: 310
City: Kings Park NY
I think I found it!
Wire running from the cans twisted piece that hold the can down running to a terminal strip!
Hope that is it?
Kirk
AC: 4 DC: 1
Threads: 337
why don`t you show a pic of chassis to help you
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM
RCA T62 is playing.....
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM
Philco 40-120C Restoration
Philco 89 indicator light.
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM
There are currently 6739 online users. [Complete List ]» 1 Member(s) | 6738 Guest(s)
