Threads: 337
City: lawrenceville nj
hey guys
I am working on a electro battery eliminator model p
no schematic and only one has one is rm and I don't want to join right now
question is what do I replace it with ?
Mallory capacitor type e.p.
3-.61ohms
max
6-2vdc
6 45
95234
that's exactly what`s on cap
2 black wires ground
1red wire checked OL
1green wire checked 30
using fluke 114 meter
thanks sam
Threads: 566
Sam
What is "Type e.p."?
Glad to help but these do not tell me much......maybe someone here had dealt with it in the past.
Who's the manufacturer?
Threads: 55
City: Lexington, KY
A picture would also help.
Threads: 566
Yes.
Also: what is this?
What's OL and 30?
- Navigator!
- Aye, captain!
- Device!
- 27, sir!
- 27 what?
- What device, sir?
Threads: 337
Threads: 566
Sam,
could you rotate it a bit so the rest of the text is legible?
This is an electrolytic, teh two blacks are minusses, red/green are plusses, could be maybe two 10uF will do.
Threads: 15
City: Paducah, KY
somewhere on there it has to be the values for the Green wire and the Red wire.
his OL is what the DMM showed
I assume 30 ohms on the other.
Threads: 15
City: Paducah, KY
I got it
your values are 6uf at 2 vdc and 6 uf at 45vdc
Threads: 337
Threads: 566
Sam
Does measuring capacitance with your Fluke give anything sensible?
1. measure between two black wires with Ohmmeter, see if they are shorted together or separate. Do not hold the bare mental with both hands - it will distort the reading.
1. Measure each black wire to each colored wire using Capacitance meter. Again, do not use hands. Only touch probes to the wires.
Threads: 337
mike
black wires ohm out to 0.1
either back wire to green is 30
either black wire to red is OL
sam
Threads: 566
Sam,
again - what 30? You are measuring on Capacitor, right? What does it say, 30 uF, nF, or? We need units. 30 by itself means nothing, unless you tell me what you are measuring (resistance, capacitance) and what the units are.
PS. Two blacks seems to be the same, two wires provided for convenience, so both caps have common minus.
Threads: 337
mike
30 is nf
OL is uf
Threads: 566
OK, so 30nF is bad, obviously, it is dry, and 0L means probably total short. Does this 0L, that is black to red, also show short on Ohms?
We need to look at where the cap is situated in the sch, I do not think those are 2V or 6V caps. Looks like 250V or 400V type.
Threads: 337
[Image: http://philcoradio.com/phorum/images/default_avatar.png]
simplex1040 [Image: http://philcoradio.com/phorum/images/buddy_offline.png]
Junior Member
I got it
sorry simplex did see your post
think it is that low ?
thanks sam
Gary
I in fact did, on a 38-14, I think, where I had a speaker with the dead coil.
Well...it kinda worked. Kinda, be...morzh — 10:38 PM |
Mike, what ever happened to that plan you had to try using a rare earth magnet to magnetize the pole? This looks like a...GarySP — 10:25 PM |
RCA T62 is playing.....
Beautiful set.morzh — 09:07 PM |
Well....here it is.
The green stuff. Unfortunately, probably penetrates deep.
I opened the top layer and saw that:
...morzh — 08:58 PM |
Philco 91 Restore Code ??
:clap: :clap: :clap: :clap:
Really nice workmanship!!! Top of the chassis looks great.
Sorry about the long winded e...MrFixr55 — 08:09 PM |
Philco 40-120C Restoration
Thank you for your reply. I will check voltages on the other tubes, look at resistor 23 and cap 25, etc. If all else fai...bluecap — 07:58 PM |
Nice looking set great save. DavidDavid — 07:48 PM |
Philco 89 indicator light.
Hello Jim, I have done several 89s. The trick is to move the drum in or out on it's shaft. You will need to loosen a set...dconant — 07:36 PM |
MrFixr
Yes, it is my plan to go with 45rpm spider if I go that far.
No, the pole was not left-handed as I unscrewed ...morzh — 07:14 PM |
Change the tube. Check the tube's bias network.
Are any other tubes experience the drop or just this?`
Is resistor 23 OK...morzh — 07:09 PM |
