Metal oxide varistor
What is the opinion of the multitudes about adding a mov on the line side of the radio. Given the modern power grids and there inherent power problems in the rural setting. Just a thought. Icon_mrgreen
Just my opinion.
Tube electronics are not terribly vulnerable to the type of surges that an MOV is designed to squelch. Rarely could they get beyond a transformer and in the case of a transformerless set (domestic radio) there's not much to damage.
Hey Robert
I too would tend to agree with that. On the other hand, I live in Florida and we have a lot of lightning and switching transients on the line. Now a lightning strike in the right situation will damage/burn up/ hurt the feelings of your power tramsformer and take the MOV any way. I put one in mine anyway as a "hopeful help" in case of a surge event. I also put a thermistor in series with its AC mains. It provides a softer start at power on and also lowers the primary volts by 5-6 volts while operating and hasn't affected the performance.
By the way, MOV devices have a finite life span dependant on their exposure to surges. A 500 JJoule device will take, 1- 500 joule hit; 2- 250 joule hits; 100- 5 joule hits; (you get the idea)in its lifetime. There is not a practical way for the average person to test them and a bad one looks as good as a new one. Yup, all those power strips youve had all these years are likely in need of replacing too!
Dave Casazza
Keep em glowin and goin...
DCASAZZA, hi. Could you expand a little on that thermistor. Size ( Ohms, Watts etc.). I have 120VAC as most people do nowadays and was looking for a way, simpler the better, to knock it down a few volts to get closer to the 110 ACV the sets were designed for. PL
Many folks are using the CL-90 Surge limiter/"thermistor". Its specs are about right for normal radios like we usually work on. You can get a spec sheet at Mouser. They will knock you down a few volts in normal operation but they also add heat in doing so. They get quite hot. Slows down warm up time but not terribly.
I'm fond of the Dale/Xicon chassis mount resistors, mainly because I inherited a good stock of 18/22 ohm ones at a good price Icon_smile Other guys cob in a bucking filament transformer which is a no-heat solution and also works well but presents physical limitations.
There are currently 11375 online users. [Complete List]
» 2 Member(s) | 11373 Guest(s)
