Philco 90 rests on top 23x
I just fixed up this philco 90 and thought it would look nice resting on top of the elusive philco 23x. It will not rest there to long to avoid any damage to the top of 23x. This picture of the to together like this is as rare as the 23x is. Thanks for looking at this one of a kind setup. Fred Taylor
I love shiny mershons...
That's what she said
Looking good Fred!
There are currently 5184 online users. [Complete List]
» 5 Member(s) | 5179 Guest(s)
AvatarAvatarAvatarAvatar
