RCA Radio Apparatus for Amateur and Experimental Use
This link popped up on the Delaware Valley Historical Radio Club mail reflector.
http://www.skywaves.ar88.net/Docs/default.html
An RCA 1921 publication "with Instructions for Continuous Wave Operation."  The link is to the full publication.
thanks bob Icon_thumbup
Very nifty i saw that one as well......radio was transformative beyond what we can think.
paul
RCA T62 is playing.....
Philco 91 Restore Code ??
Philco 40-120C Restoration
Philco 89 indicator light.
