Resistor values question
#31
Ok what toob was it hooked to??
Not at the house so I will have to check tomorrow.
This diagram says it is either .000020 or .000010mfd. Cant tell if the first color is red or brown
http://www.antiqueradio.org/art/recap13.jpg
Kirk
Just put a 25mmfd cap in it and be done w/it.
Don't think its in a tuned circuit its a coupling cap.
If that cap exploded, its probably C21 which is connected across the AC line. That's not a mica cap but an infamous Micamold paper cap, which looks like its rated at 0.1 uf, 400 V. The explode regularly when used as a line cap.
#35
Is it ok to use. 450 volt 8 mfd I. Place of a 500v?
I am working on a halson 50R and the 50x has the same tube lineup.
http://www.nostalgiaair.org/PagesByModel...008951.pdf
I am replacing the ecaps and there is that infamous box cap. It says 8 on it. But under it the positives are cut. Could this 8 @ 500 be the replacement?
Here are some pics
Kirk
And this pic
New member
Good picture, When was it taken? You don't look in it like a guy who has a teenage son :)morzh — 06:13 PM
New member
Philco 630csx power cord
New member
There are currently 4136 online users. [Complete List]
» 2 Member(s) | 4134 Guest(s)
