Re conditioning record platter
What is the process called when you re condition the record platter?  I bought a 53-1750 radio/phonograph and the felt like material on the platter is worn down, rough and hard.   Does anyone know what company(s) are available to strip and recoat this felt like material on these old platters?   Thanks,[Image: http://philcoradio.com/phorum/images/smi...nfused.gif]
It is called flocking or getting your turntable platter re-flocked. There are a number of companies and individuals that can do this. You can also buy a bag of what ever color brown or black flock and a "flour sifter" to reflock your own. Mostly they use a flocking gun that sprays the product onto a wet painted surface and most of it sticks, then some of it does not.
See this post over at the "other" forum. http://www.antiqueradios.com/forums/view...?p=1298496
Tony
Very helpful - thank you.
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Make sure the person who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM
Model 27-84 BUZZ?Humm?
There are currently 1561 online users. [Complete List]
» 3 Member(s) | 1558 Guest(s)
