Replacement model 20 output transformer
Hi everyone
I have a Philco model 20, which uses PP 71A's and I need to replace the output transformer. I would like to use a Hammond 125C, which is rated at 8 watts. What I need to know is what should I be using for the primary impedance for PP 71A's.  Voice coil impedance is: VC=1.5 X DC resistance, which, in my case, means 1.5 X 1.4 so the voice coil impedance is 2.1 ohms. What taps should I use for the correct primary impedance with the PP 71A's? I have forgotten as all I used to have to do was look up the original part number and cross it over the the replacement number and put it in! By the way, my speaker isn't the original Philco, it is a Jensen, of the same size that has been reconed and has a new field coil installed too.
Michael
If your speaker is original, you want the outputs 3 and 4 as they provide close to 1:100 ratio you have in 20 output xfmr.
Otherwise we need to know if it is not original.
http://www.hammondmfg.com/125.htm
Truth is almost any output transformer from the era will be OK, worst match would mean lower maximum volume. If you get a "universal" one adjust for best tone/volume.
(03-30-2015, 11:48 AM)codefox1 Wrote:  Truth is almost any output transformer from  the era will be OK, worst match would mean lower maximum volume. If you get a "universal" one adjust for best tone/volume.
Thank you to everyone. I am using an NOS transformer that had the paper work with it showing how to wire it for PP 71A's as well as all other output tubes of the era. So my problem is solved.
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Make sure the person who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM
Model 27-84 BUZZ?Humm?
There are currently 1588 online users. [Complete List]
» 3 Member(s) | 1585 Guest(s)
