42-1012 Tone control
Picture of Part
[Image: http://i292.photobucket.com/albums/mm38/...xdqbs0.jpg]
According to schematic the center contact on this pot should go to ground. But it never did. Did philco goof? this could never work as tone control it Part # 67 Tone control ( Audio base)
Thanks
Skip...
Measure the wiper to gnd with an ohm meter. It may have an internal gnd connection. If not gnd it.
Yes, it is usually connected without being soldered.
Yup center is grounded.. Thanks never seen a pot that the center was grounded internal.
Thanks
Skip...
Sometimes it is a ring riveted to the middle pin (or soldered) that goes around the shaft so when mounted it provides the grounding.
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Make sure the person who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM
Model 27-84 BUZZ?Humm?
There are currently 1639 online users. [Complete List]
» 1 Member(s) | 1638 Guest(s)
