  • 1 Vote(s) - 3 Average
Model 57 compensator values?
Have you aligned the RF and IF stages with a signal generator? These sets to work properly need a good alignment especially after moving the wiring around while fooling with the trimmer caps. I trust that you have replaced the paper caps and checked the resistors to be intolerance.
I replaced all the caps and resistors. The alignment process is impossible with this confounded oscillating problem...I hate to give up on it but I need to move on right now. I will most likely go back to it in a couple months.
Happiness is a warm glowing radio!
What u can do is turn down regeneration till it's not oscillating then do the alignment. That may help.
Gud lk
You don't understand. I can back that one off all the way but if I try to get anything coming through the speaker using the other trimmers and tuner it still spills over.
I checked all the trimmers according to Ron's ID of the letters. They are all in the right places. Any other ideas???
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Make sure the person who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM
Model 27-84 BUZZ?Humm?
There are currently 1643 online users. [Complete List]
» 1 Member(s) | 1642 Guest(s)
