41-280 Speaker Plug Repair
The little cardboard disc that is riveted in on the cable side fell apart.
What is the best way to redo this piece?
Drill out and tap?
What material for a new disc?
Picture alwayis helps. Anyway, if it's a piece of cardboard, another piece of cardboard or any non conductive material should work.
I'll have to take one and post since I can't seem to find similar online anywhere.
[Image: http://i1289.photobucket.com/albums/b519...jedgvp.jpg]
I don't think I'd do anything in your shoes. Just don't ever try to put the plug in the speaker with the power on, else you might put the full rectifier voltage on the voice coil while you're wiggling it to orient it right. You shouldn't do that anyway.
I'm not sure where the other end of that rivet is, but if it is on the back side of the plug, you could drill it out, make a new cardboard piece with the holes in the right place, and put it back with a self-tapping screw just a tiny bit larger than the hole.
Or you could glue the new cardboard piece in place. There are some tenacious glues that will probably hold well. Aleen's Tacky Glue seems to bond well to cardboard and to plastic. I used to think it wouldn't bond well to plastic, since it looks just like Elmer's, but it has bonded to whatever kinds of plastic I've used it on. I don't know how it would bond to that particular plastic, but since it doesn't bear any load there's a good chance it will be plenty good enough.
John Honeycutt
There’s a lot of different search results for trust auto. I did confirm he takes Venmo, but I’ve got one last test. I as...jrblasde — 02:01 PM
Philco 91 Restore Code ??
I did the math to calculate the wattage of the resistor and found to be 47.16 watts using 3275 as fc resistance and your...dconant — 01:30 PM
New member
Hello all.  New member here. I bought a Predicta TV for my teenage son (who is into all things vintage, see attached pic...Jsmith5690 — 12:47 PM
I’ve asked if they accept PayPal as payment so that I can contest it if the part doesn’t arrive.jrblasde — 12:46 PM
Make sure the person who answered is not a scammer (lots of these there now) and the Trus A S, whoever they are and wher...morzh — 12:38 PM
Model 27-84 BUZZ?Humm?
There are currently 1617 online users. [Complete List]
» 3 Member(s) | 1614 Guest(s)
