Need Help Identifying this Philco
I am headed to look at this one today. I did not see a similar cabinet in the gallery. The ID label is not quite clear enough to read. Partial shot of the chassis gives me the idea that it might be a 11 tube model 16 chassis. Any ideas?
pics?
-Mars
(04-17-2015, 11:56 AM)Marsupial Wrote:  pics?
Oops forgot to add pictures. They are added.
Oh, that one again. I thought it sold a few months ago.
I believe it was identified but that the bottom was custom made.
Kirk
Philco Model 17 chassis in a custom (third party) cabinet.
Thanks Ron
I went ahead and paid the seller a visit. Decided to take it home.
That must have been a popular cabinet maker/company because a local radio club member has a philco 71 in that same cabinet.
I have to admit, that cabinet does have a neat look to it.
Now that it's home with some clean up here are some better shots
How tall is it?
Looks like a different solution to 'No stoop no squat no squint'... Put it up higher in the air!
How tall is it?
Gotta change those knobs.
The cabinet does have a distinctive 30's feel, kinda cool.
Nice find ! I wish you would post some pics of the chassis, but perhaps you are saving those for the "electronic restoration" section. I really look forward to following your progress with this radio. Good luck !
Roy, I love that cabinet! Those legs are not likely to come off. Just a unique and pleasing style. Much more interesting than most radios from that era.
Jerry
There are currently 5078 online users. [Complete List]
» 4 Member(s) | 5074 Guest(s)
AvatarAvatarAvatarAvatar
