How To Remove Dial Pointer - 38-12
Could someone give me advice on how to remove the dial pointer on a Philco 38-12? The pointer needs to come off so I can remove and clean smoker residue from the tuning capacitor.
Richard
It just pulls off. You may have to twist it back and forth a bit (carefully, while holding the tuning condenser plates fully meshed; that is, closed) but it should just pull off. In case of corrosion, do be careful...
Thanks, Ron. That worked. I was being too careful before.
Richard
Nothing wrong with being too careful - that is preferred to the "bull in a china shop" method. Icon_wink Good luck! Icon_thumbup
Welcome to the Phorum Richard!!!
Thanks, Bob. I originally joined a couple years ago but didn't visit the forum for several months. Then, when I tried to log on, I had forgotten my password and couldn't get a new one because my email address had changed. So...I rejoined.
Richard
Welcome, Richard Icon_thumbup  Good luck with your 38-12
Eric
The Villages, FL
There are currently 5026 online users. [Complete List]
» 1 Member(s) | 5025 Guest(s)
