Aww! What a cute wittle wadio!
Threads: 22
City: Gardendale, AL
I picked this Philco 41-225 up at the AHRS today for $10. It's going to need a little work, a new cord and such. The speaker's caved in, but the veener is very nice. A little GOJO and I'm sure it will clean up nicely. I blasted all the dust out of it with some canned air.
Image(s)
Slave to an RCA Victor CTC-25
Threads: 563
Took me a while. Widdle means urinating .....?
Threads: 26
City: Hayward, California
(05-03-2015, 12:45 AM) morzh Wrote: Took me a while. Widdle means urinating .....?
Widdle is Baby Talk for "Little"
Or, ...
"widdle wadio" is Elmer Fudd-speak for "little radio".
Threads: 22
This is the smallest Philco I have. Hence, it is a baby.
Threads: 310
City: Kings Park NY
Mike its "piddle" silly Ruski!
Kirk
AC: 4 DC: 1
Threads: 415
City: Boston
You know you could have bot that on Ebay for 100.00! That little set could look slick. Pushbuttons look OK and it has call letters too. It is the right size for about a wall full of say like 50 small Philcos. Good luck.
Threads: 22
This thing's speaker is toast. Does anyone know the power and resistance for it and where I can get a new one? How much does reconing cost?
Threads: 268
Well the original FC is 500 ohms which is pretty low. I suspect that's done so there isn't much voltage drop across it. What most later AC/DC set use is a 1000 to 1500 ohm resistor @ 5W. When don't have the FC in the circuit you will need to up the value of the filter caps. The FC provides some filtering the resistor not so much. So replace those with 47mfd @160v. This will give you a nice clean power supply.
As for the recone I'd guess about $45.
I see you got a local set it's got WSM on it.
Kirk, HaHa very funny!!!!!
Threads: 22
The current electrolytics are a Cornell Dublier dual cap at 30 and 50 mfd and 150 volts.
Threads: 563
(05-03-2015, 09:57 AM) OldRestorer Wrote: Mike its "piddle" silly Ruski!
Kirk
Though It is a UK version, but it is also what I said.
Verb Edit
widdle (
third-person singular simple present widdles ,
present participle widdling ,
simple past and past participle widdled )
(chiefly UK ) To urinate
Threads: 268
Thought you did that with a pocket knife and a stick. Didn't know they did it in the UK.
The CD cap is replacement. Original was a dual 20mfd 150v.
(This post was last modified: 05-03-2015, 01:35 PM by
Radioroslyn .)
Threads: 26
(05-03-2015, 12:30 PM) morzh Wrote: (05-03-2015, 09:57 AM) OldRestorer Wrote: Mike its "thepiddle" silly Ruski!
Kirk
Verb Edit
widdle (third-person singular simple present widdles , present participle widdling , simple past and past participle widdled )
English isnt so simple is it? ; )
Threads: 563
Nope. That is, simple enough but since we are separated by the common language that complicates things just a smidge.
Threads: 26
(05-03-2015, 02:52 PM) morzh Wrote: Nope. That is, simple enough but since we are separated by the common language that complicates things just a smidge.
Yea, it doesnt help with all the "slang" terms we all come up with either.
Let's try to sort it out. So we are working with the same info here's the schematic I have:
...and here's the pin o...klondike98 — 09:03 PM
Philco 630csx power cord
I posted this on FB but knowing that not all of us use social media, it seemed sensible to ask my question here.
I r...Tynwald — 08:07 PM
Philco 40-155
At last, got this working well. Impressed has really nice reception and tone. Had a bad connection on one of the capaci...rogerh — 07:44 PM
Philco 91 Restore Code ??
Or you could just square the current :lol:
As for the values, they are dependent on the 1 or 2-speaker system.
The...morzh — 05:46 PM
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001).
It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47.
The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic.
I have gone through most of the cap replacements. I...dconant — 01:26 PM
There are currently 1509 online users. [Complete List ]» 2 Member(s) | 1507 Guest(s)
