A question: old console radios manufacturing quantities
#31
(05-11-2015, 03:35 PM)morzh Wrote:  To moderators: I think this two radios discussion should be moved to a separate topic, maybe in Home radios or restorations.
Your wish is my command, sir.
Done.
Thanks Morzh for being our translator! In any event, we are very happy that Peter has joined us!
Joe
There are currently 7830 online users. [Complete List]
» 3 Member(s) | 7827 Guest(s)
