Search button not working on this site
C Icon_thinkCannot get the search feature to to recognize my command to search this website Icon_think What gives?
(05-16-2015, 11:55 PM)Fred Taylor Wrote:  C Icon_thinkCannot get the search feature to to recognize my command to search this website Icon_think What gives?
False alarm I figured it out Icon_crazy Icon_clap
It is a bit touchy.
Carl
Northern Panhandle, WV
There are currently 2236 online users. [Complete List]
» 1 Member(s) | 2235 Guest(s)
