Philco Part
I'm trying to purchase a Philco part from Vintage Electronics, but need to talk to the owner first. None of the contact links are working on his site. Anyone have a contact number or email address? Thanks.
John's snail mail and email are on his first page. The email on the "Contact John" link is the one I've always used. Its a one man operation so he may just be away.
(05-21-2015, 10:57 AM)klondike98 Wrote:  John's snail mail and email are on his first page.  The email on the "Contact John" link is the one I've always used.  Its a one man operation so he may just be away.
Appreciate the reply, but I've worn out 3 fingers clicking that dead link. Like you said, the one-man band must be playing out of town.
Hey John,
  Have you tried Mark at oldradioparts?
He has some goodies.
Kirk
http://oldradioparts.com/
Mark (Oppat) is at http://www.oldradioparts.net .
Gary Schneider is at http://www.oldradioparts.com .
Confusing, isn't it? Icon_crazy
(05-21-2015, 10:08 PM)Ron Ramirez Wrote:  Mark (Oppat) is at http://www.oldradioparts.net .
Finally the oscillator coil I needed showed up on the Vintage Electronics site. I quickly ordered it and all was right in the world. I no longer need his email address (until I'm in trouble again).
One less problem.  John (jmac3ky)
There are currently 5513 online users. [Complete List]
» 5 Member(s) | 5508 Guest(s)
AvatarAvatarAvatarAvatar
