16b capacitor value?
Does any body know the cap values for tone control switch, there inside a tar box and nothing on schematic or parts list that states the value , its on a 16b tombstone. There may 2 or 3 of them inside, haven't removed old one yet.
Fred,
This might help:
http://philcoradio.com/phorum/attachment.php?aid=3308
Carl
Northern Panhandle, WV
(05-29-2015, 07:51 PM)Carl Travis Wrote:  Fred,
This might help:
Thanks
There are currently 4936 online users. [Complete List]
» 1 Member(s) | 4935 Guest(s)
