Philco transistor radio alighment is this the wrong forum
Hello everyone,
Well I just replaced the volume control also recaped my little Philco T-800 I was wondering if this is the wrong forum but what I said this is a early Philco transistor what heck Ron or Chuck don't Bite Icon_lol I figure ask away so should I perform alighmen on this radio or do you think it will be alright to leave as is I still need to check resistors thou.
and I used good old Sprague atom caps when I recaped it to so they should be good for the life of this radio.
Sincerely Rich
Hello everyone,
I have been playing that radio most of the day off of my home brew powersupply and seems to work goo so maybe I'll just clean it up and put back together for now.
Sincerely rICH
Hi Rich
This is the RIGHT forum! Icon_biggrin
Any radio will benefit from a complete, thorough and proper alignment. By that, I mean performed to factory specifications, using known good instruments such as a well calibrated signal generator and output meter or oscilloscope to display the output, and using the factory alignment instructions.
Personally, I have a frequency counter tied into my signal generator, and use an oscilloscope as an output indicator. YMMV.
Hello Ron,
Well thanks for the advice far as the right forum I know it's a Philco but it's a 1958 transistor radio not a Philco 90 .
I guess we must think alike I to have my fluke/Phillips Freq counter hookes up to my signal gen. it really makes it handy that why to get right on the mark . I using the sams photofacts for this radio thou.
Sincerely Rich
Philco 91 Restore Code ??
If you know the fc resistance you can use 120 ma nominal current through the resistor to get the voltage drop then calcu...RodB — 05:21 PM
Thanks Mike. I at least know why it is there if I don't fully understand it. I see where you talk about a cap and resist...dconant — 04:49 PM
Well, this cap you showed cannot possibly, due to the way it is constructed, be 1000pF (0.001). It can be in tens of pF....morzh — 03:13 PM
I have two schematics for this radio one shows the 47 block (126-226) and the other (121-221) does not. My radio does no...dconant — 02:32 PM
No, that cannot be the 47. The 47 is a regular backelite block cap. Look at the chassis picture, it is shown there. Rig...morzh — 01:45 PM
I have changed the title of this thread from Philco 91 Schematic. I have gone through most of the cap replacements. I...dconant — 01:26 PM
Here is an online transistor substitution site… Ron462ron — 08:44 AM
One way to repair a broken wire on a coil is to take a copper strand out of some 18 gauge electrical cord, make a &quo...captainclock1988 — 12:55 AM
Hello Tim, I once had a Jcpenny 13inch tv /monitor built by NEC come into my repairshop it would start acting up at tim...radiorich — 10:59 PM
Restoring Philco 96
Mike; The last time I took a potted condenser can apart, and it was maybe 1/4 the size of the one in the model 96, I ...Arran — 10:56 PM
There are currently 3270 online users. [Complete List]
» 4 Member(s) | 3266 Guest(s)
AvatarAvatarAvatarAvatar
