TWO 16b tombstones/ FINISHED!
Threads: 147
City: Dallas, TX
Threads: 22
City: Waxahachie, TX
Threads: 147
City: Dallas, TX
Agree with Crist - looks good ![Icon_thumbup Icon_thumbup](https://philcoradio.com/phorum/images/smilies/icon_thumbup.gif) Probably the next best thing to plating, color-wise.
However, is this paint conductive?
Threads: 147
City: Dallas, TX
The color of paint for the shields is called chrome , that's what rustoleum calls it. I don't know if its conductive but Dick Morgan states that as long as tube shield is grounded good it doesn't matter what kind of paint u use
(This post was last modified: 06-08-2015, 07:26 PM by Fred Taylor.)
Threads: 22
Thanks Fred. I'm going to get some of the stuff. The shields look great!
Crist
Threads: 26
City: Hayward, California
(06-08-2015, 07:25 PM)Fred Taylor Wrote: The color of paint for the shields is called chrome , that's what rustoleum calls it. I don't know if its conductive but Dick Morgan states that as long as tube shield is grounded good it doesn't matter what kind of paint u use ![Icon_think Icon_think](https://philcoradio.com/phorum/images/smilies/icon_think.gif)
I'm pretty sure that's why you want conductive paint, so it will be grounded. Otherwise if it's not conductive it wont make electrical contact, unless you scrape off the paint at any points of contact.
(This post was last modified: 06-08-2015, 11:27 PM by Warren.)
Threads: 147
City: Dallas, TX
(06-08-2015, 11:26 PM)Warren Wrote: (06-08-2015, 07:25 PM)Fred Taylor Wrote: The color of paint for the shields is called chrome , that's what rustoleum calls it. I don't know if its conductive but Dick Morgan states that as long as tube shield is grounded good it doesn't matter what kind of paint u use ![Icon_think Icon_think](https://philcoradio.com/phorum/images/smilies/icon_think.gif)
I'm pretty sure that's why you want conductive paint, so it will be grounded. Otherwise if it's not conductive it wont make electrical contact, unless you scrape off the paint at any points of contact. That's what I did was remove some paint on bottom edge of shield, now I have a good ground
Threads: 147
City: Dallas, TX
Threads: 22
Well done Fred!
Crist
Threads: 562
Looking good!
Threads: 337
City: lawrenceville nj
Threads: 562
The paint does not matter fir the shields as long ss you leave the internal base part bare so it connects to the chassis, the rest you can cover with latex based for all I care as long as you like it.
Threads: 147
City: Dallas, TX
(06-12-2015, 12:25 PM)morzh Wrote: The paint does not matter fir the shields as long ss you leave the internal base part bare so it connects to the chassis, the rest you can cover with latex based for all I care as long as you like it.
I mentioned that already and you are right, as long there are grounded good.
Threads: 40
City: McPherson, KS
Those sure are purty radios!
A minor point: I thought the knobs on the earlier and later versions were different.
Users browsing this thread: 15 Guest(s)
Hi Rod,
Hello Tim,
Hello Tim,
Hi Dan,
There are currently 10506 online users. [Complete List] » 2 Member(s) | 10504 Guest(s)
