  • 1 Vote(s) - 1 Average
Model 37-84 Help Needed
#46
A 37-84, as well as the older 84, 81 or 80 requires a long antenna and a good ground. By "long" I mean 50 feet or better. 25 feet might do; 10 or less is all but useless to one of these four-tube wonders.
In that case, this might just become a nice display piece.
#48
Subdivision with a HOA?
No. Wife.
#50
Oh. Worst-case scenario. Icon_silent
[Video: https://www.youtube.com/watch?v=sBmFwKH5bVY]
Users browsing this thread: 14 Guest(s)
