Threads: 310
City: Kings Park NY
Grrrrrrrrr!
Tried stripping Mikes cabinet today and found out that it was polyurethaned!
Now I have to Bix it!
Me
AC: 4 DC: 1
Threads: 562
He's a feisty lil'fella, ain't he!
Threads: 55
City: Lexington, KY
Has anyone heard from Kirk lately?
Threads: 562
No. I wrote him, no reply yet. Hope he's OK.
Threads: 310
City: Kings Park NY
Working on the center cabinet issues. The veneer had buckled on a burl in the veneer causing a lift and separation right in the center of the cabinet arch. Making an insert to back the cabinet while clamping.
Image(s)
AC: 4 DC: 1
Threads: 72
City: Linn Creek, MO
I don't think the veneer on the wrap-around is original. I have never seen a Clyde Shuler Philco cabinet with the grain running up and over.
M R Radios C M Tubes
Threads: 562
Judging by the finish (however damaged it was) when I got it, the finish was original. If it was, so was the veneer. Unless it wasn't.
Threads: 310
City: Kings Park NY
Possible...
The holes in this cabinet are definitely suspect. They are deep like someone covered them without filling them.
It is a very old finish if it is re-veneered.
I have seen them with the grain running this way though.
Me
AC: 4 DC: 1
Threads: 337
City: lawrenceville nj
kirk
hope your wearing a good mask
take it easy with chemicals
we want to see you at ktown
Threads: 562
Yeah, I am bringing a cigar I bought in Florida
I think tobacco is safer than paint chemicals.
P!us keeps away mosquitoes and unwanted conversational partners.
Oh....and a cooler too!
Threads: 310
City: Kings Park NY
I have made the insert for gluing the center issues on the cabinet.
I will apply the Glue and clamp the heck out of it until tomorrow.
I went and got new filters for my mask so hopefully these odor blockers will help instead of the dust ones.
They will be good for when the boys come over too
Me
AC: 4 DC: 1
Threads: 310
City: Kings Park NY
im finally gonna try to repair the veneer issues on the center of the arch.
Image(s)
AC: 4 DC: 1
Threads: 310
City: Kings Park NY
Back to work!
AC: 4 DC: 1
Hurry up! Kutztown is only a month away!
Threads: 310
City: Kings Park NY
I think I am finally done gluing!
This cabinet will not be perfect but it will be a lot better.....
Image(s)
AC: 4 DC: 1
Users browsing this thread: 35 Guest(s)
Hi Rod,
The resistor connects to pin 4 and the ungrounded side of block 9. From pin 9 of the RF tube to one side of ...dconant — 09:34 AM
Hello Tim,
Sincerely Richardradiorich — 01:55 AM
Hello Tim,
Sincerely...radiorich — 11:07 PM
Hi Dan,
I can't explain this specific resistor but I have seen the use of a switch to apply B+ voltage to screen gri...RodB — 09:36 PM
And I suspect whoever repaired it, wanted to re-use old transistors' pin stubs in o...morzh — 09:24 PM
There are currently 9734 online users. [Complete List ]» 1 Member(s) | 9733 Guest(s)
