What type veneer for 41-280?
I was looking at my sheet of walnut but it doesn't look quite the same. My sheet looks like it has more defined lines than the 41-280.
Maybe its just me Icon_smile
Lets see a few pictures of what you got going on. Its ether mahogany or walnut is my guess, there is a lot of photo finish on that set which is fake wood grain and if your trying to match that you cant.
Only photo finish I can tell are on the front colums.
Here is a pic of side and veneer I have. Maybe it is to close of a shot???
[Image: http://i1289.photobucket.com/albums/b519...5cqpgh.jpg]
(07-09-2015, 12:15 AM)Edisla Wrote:  Only photo finish I can tell are on the front colums.
It's French Walnut, possibly quarter cut, but that's the species you need to look for.
Well pooh I don't have any of that. Time to start looking.
There are currently 5582 online users. [Complete List]
» 1 Member(s) | 5581 Guest(s)
