Tool for Philco Compensating Condensers
Where can I find a tool for adjusting the trimmers (compensating condensers) in the Philco Cathedrals (Model 60, 89, etc)? It looks like I need a small socket wrench-type tool (pencil size) that will fit the little hole and the little nut. It should be non-metallic of course.
It has to be somewhat "hollow", since there is usually the end of a threaded post sticking out through the adjusting nut.
You guys know what I mean.
I try to adjust them from the side with a pair of needle noose pliers. To say this doesn't work very well is an understatement.
Mark K8KZ
http://philcoradio.com/phorum/showthread...89#pid1389
[url=http://philcoradio.com/phorum/showthread.php?tid=242&pid=1389#pid1389][/url]Here's a thread on the topic
Yes, I used a ball pen tube and heat formed it around a nut of a proper size.
Wow! Great thread and great tips!
Thanks guys!
Mark
There are currently 6050 online users. [Complete List]
» 3 Member(s) | 6047 Guest(s)
